Sealed Bearings in transmission and Fastenal Bearings.
Curt from Minne
07-20-2007 12:15:26
I am rebuilding my B transmission and need to also replace the bearings in the PTO assembly. I can get sealed bearings at Fastenal for a very good price. I have not priced out bearings from any other places yet but the Fastenal are about $6 for one. Any ideas or thoughts on putting sealed bearings in a transmission. The price somewhat scares me as being to low but I do not plan on using the pto on this thing anyway. Also has anybody had any luck or experience using an online bearing supply source rather then a local bearing shop? Using Google,I still have not found a good online bearing shop. thanks for the replies
ShaggyM
07-20-2007 21:42:47
 Re: Sealed Bearings in transmission and Fastenal Bearings. in reply to Curt from Minnesota, 07-20-2007 12:15:26
I just bought a full set of bearings for my Farmall B trans and I have $140 in the bearings and another $30 in the 3 seals. And that is from the local Carquest and using the company discount from where I work.
Shaggy
Janicholson
07-20-2007 15:01:30
Gary below is correct, a sealed bearing may prevent lube from getting to other parts. Pulling the seals is easy with a dental pic. Make sure the new bearings have the same groove depth as the old. Bearings with the same dimensions are not alike. JimN
Brad in WI
07-20-2007 12:18:43
Call your local or somewhat local Case dealer they may suprise you on price. Also check at a Napa or Carquest. if you have the sizes of the old one they may be able to get you one for a good price. just my .02 cents worth
IaGary
07-20-2007 14:44:37
 Re: Sealed Bearings in transmission and Fastenal Bearings. in reply to Brad in WI, 07-20-2007 12:18:43
If the factory bearings are not sealed, Make sure you pull the seal out of the bearings so they get lubed.
Gary
