282 diesel
Larry mapes
07-21-2007 19:16:56
i put a crank kit into a 282 diesel, bled it and it will not start. changed the injector pump and still wont start. HELP!!!!! !!!!!
Jason Simmerman
07-22-2007 08:02:56
 Re: 282 diesel in reply to Larry mapes, 07-21-2007 19:16:56
Did you disturb the valvetrain in any way? It almost sounds like it is loosing compression that's why it won't fire off.
Owen Aaland
07-21-2007 20:04:19
Are you getting any smoke out of it? If you do not have smoke you are not getting any fuel delivery. Did you just replace the crank or did you have more apart?
If you are sure you have all the timing marks lined up in the gear train the only other thing is the drive lug on the injection pump drive shaft. Looking at the back end of the shaft there is a dimple toward one side. There is also a matching dimple inside the pump where the shaft mates up. Both dimples must be on the same side or the pump will be 180 degress off. A lot of engines will run 180 degrees off but there ill be a lot of smoke and very little power.
larry mapes
07-22-2007 03:07:34
 Re: 282 diesel in reply to Owen Aaland, 07-21-2007 20:04:19
I just replaced the crank had all of the timing marks lined up when i put it together i even tried (shame on me )either all i got was a whole lotta smoke and a dead battery
Owen Aaland
07-22-2007 10:14:56
 Re: 282 diesel in reply to larry mapes, 07-22-2007 03:07:34
Two more questions. Did it start OK before the cranks kit? Are you sure the glow plugs are working?
Larry mapes
07-21-2007 19:17:57
does anyone know what happens when u get the injector pump 180 degrees out?????
Bob
07-21-2007 21:27:48
 Re: 282 diesel in reply to Larry mapes, 07-21-2007 19:17:57
"does anyone know what happens when u get the injector pump 180 degrees out????? "
Yeah, it won't start.
Jimmy King
07-22-2007 11:04:18
 Re: 282 diesel in reply to Bob, 07-21-2007 21:27:48
Yes it will start, maybe only by pulling it. They will start ,but will not have any power. It does sound like it could be 180 out, or the glow plugs are not working
