460 Hydraulic Pump Problems
Needs Help
07-22-2007 20:00:11
A friend at work needs help.He hays with a 460 Diesel.The hydraulic pump was getting real slow so he put a new hyd pump and PS pump on.
It didnt steer good so he put the old PS pump back on.It steers fine now but about after 15 seconds the hyd pump seems to be building up pressure and pulling the motor down.He will move the hyd lever some and its fine for 15 seconds and then does the same thing again.
He wants your opinions on this.Thanks.
HIGGI
07-23-2007 14:50:15
 Re: 460 Hydraulic Pump Problems in reply to Needs Help, 07-22-2007 20:00:11
READ THE LINK THAT THEY GAVE YOU HERE
MY GUESS IS THE ORFACE IS PLUGGED IN THE VALVE BLOCK ....GOOD LUCK
BEEN THERE DONE THAT COULDNT WITH OUT THE HELP OF IT MANUAL AND OLD OAK FARMALLS
Joe Evans
07-23-2007 05:08:56
Try this.
CNKS
07-22-2007 20:05:15
I assume he changed the filter, which is on the opposite side of the housing?
Needs Help
07-23-2007 22:36:36
 Re: 460 Hydraulic Pump Problems in reply to CNKS, 07-22-2007 20:05:15
My friend said to tell all of you thanks.It has a new hyd filter.They are going to tear in to it tomorrow.
