Made some more progress on my basket case H
neblinc
07-23-2007 07:01:09
Went and bought a HF 20 ton press that was on sale, plus 15% off this weekend to see if I could get the last 3 pistons out by pressing them out as recomended by Tractor Vet.
Well the first one made a loud bang and popped loose, every 1/2 inch of pressure it would bang and move more, wife came in the shop wondering what I was up to since it was so loud.
Got 1 out and the 2nd came out the same way, but, that 3rd one is still under ram pressure since Saturday and has not popped free yet, will give it more time I guess and see what happens.
Worked on the head also, my neighbor has all the good tools for working on these engines third party image
Some more pics on the link below.
Randy
H Progress Pics
John A.
07-23-2007 18:48:38
 Re: Made some more progress on my basket case H in reply to neblinc, 07-23-2007 07:01:09
neblinc, Try this....Take the block out of the press, get it outside, fill the #3 cylinder with diesel, add a splash of gas, set on fire, let it burn itself out, Now>>>>go press that piston out. the heat of the fire will expand the sleeve and allow the piston to be pressed out more easilly. Hope this helps.
Later,
John A.
PS if that piston is more to TDC then you may need to repeat the process 2 or 3 times. Later.
Paul G. in Mn
07-23-2007 18:25:09
Sure hope the engine in my 39 H breaks free easier then that but gives me idea's if need be. Thanks for posting the pictures.
Mike CA
07-23-2007 14:09:22
Randy, for the sake of good entertainment, I think you should quit your job and work on the '50 H full time. This is far too interesting to watch to not get weekly updates on!
GordoSD
07-23-2007 12:26:34
You should try to push those pistons out the top. When water gets in the engine it goes to the cylinder and piston. Then rusts solid. Very little water ever gets between the sleeve and the block because of the press fit. Going from the bottom out the top , most likely the sleeve will give up easily. You are going to have to take them out anyway.
Gordo
neblinc
07-23-2007 08:39:41
Yeah Rusty, I got there around 7 Sat morning and left around 11.
we should have exchanged cell phone #s
Randy
RustyFarmall
07-23-2007 08:09:33
Randy, did you make it to Waverly? I didn't see you, but then I think most of us just kinda got lost in the crowd.
the Unforgiven
07-23-2007 12:37:45
 Re: Made some more progress on my basket case H in reply to RustyFarmall, 07-23-2007 08:09:33
Wish I had known you guys were there, I gave up on the F30 and loaded the Galloway sawrig, and had a blast sawing.
