super c front axle
Rick in Vermont
07-23-2007 15:59:05
I have a Super C with a wide adjustable front axle. I have put a ton of penetrating oil on it and tapped it forever. I cannot get the extensions out of the axle tube. Does anyone have any suggestions on how to get them apart. I haven"t used any heat yet.
rnicholas
07-23-2007 17:54:03
 Re: super c front axle in reply to Rick in Vermont, 07-23-2007 15:59:05
Prepare to put forth no small amount of effort. Once it happens it'll happen all at once. Until then you won't know if you're any closer to getting it un-stuck. If it's never been extended it can get really fixed in there.
georgeky
07-23-2007 16:31:57
You have the answer. Put the heat to it and it will give eventually.
