H Just Popped!
IndianaRed
07-23-2007 16:18:25
OK, While turning over I held my hand over the intake, when I stopped turning over and removed my hand, quite a bit of fuel started to come out so I tried turning over right then. Sucked that fuel up and popped. Kept popping as long as I held starter, but doesn't run. But those are the fisrt signs of life.
Help any with diagnoses?
Thanks,
Brian
neblinc
07-24-2007 08:02:37
 Re: H Just Popped! in reply to IndianaRed, 07-23-2007 16:18:25
And you told me you had the screw set correctly third party image
Good thing you double checked.
Randy
Lanse
07-23-2007 19:03:06
CONGRADULATIONS!!!!! ! I am wanting to get me an H but am not sure if I'm ready for a total engine rebuild. I am 14 and work on garden tractors, and if you were me, would you go ahead and get one and bite the bullet or try to get one without a stuck engine? I want a not-stuck one, but I'll take what I can afford, and a ***new*** (rebuilt) engine would be nice-If I do it right, doing it again could be my grandkids problem!
IndianaRed
07-23-2007 20:30:47
 Re: H Just Popped! in reply to Lanse, 07-23-2007 19:03:06
You don't have to get a stuck one, or one that needs much engine work at all. There are quite a few listed in photo ads here that supposedlt run pretty good for right around $1000, a few for less. If you 14 someone might cut you some slack to see a kid doing something positive with your time.I think a stuck one you should be able to get for next to nothing, a couple hundred bucks.
But if I were you, I'd get a decent running one. And by the time you save 8 or $900, it would be easy to save a few hundred more and get a really decent one. You can get a really nice one for well under $2,000.
Git to it.
Brian
El Toro
07-23-2007 17:10:38
I think you need to check to see if your distributor is in time again. Bring No1 piston to TDC on the compression stroke. Your notch on the damper pulley should be aligned with the pointer and both valves on No1 cylinder should be closed. Then look at the rotor to where its pointing. Your plug wires need to be in this firing order on the cap too. Hal
2-1
4-3
PS: You can have fire at all the plugs even if the distributor is timed wrong. It's just not firing in the correct order.
RustyFarmall
07-23-2007 18:00:02
 Re: H Just Popped! in reply to El Toro, 07-23-2007 17:10:38
Yep, double check that timing.
IndianaRed
07-23-2007 18:06:23
 Re: H Just Popped! in reply to RustyFarmall, 07-23-2007 18:00:02
Hey Rusty, She's running!!!! This is the greatest day of my life! lol Not perfect yet, but running. I went back to the archives and searched on carb settings, just to make sure. Turns out I had the high speed adjust all the way in, starving apparently. Let her out and started right up. I didn't think that would affect starting that much, but it did. Feel like I'm learning book loads everyday.
Sure do appreciate your interest and assistance. Definately could not have done this without this site, you and all the guys.
Can't wait to get her out to that farm for some baling!
Thanks again,
Brian
John-Paul T
07-24-2007 11:38:13
 Re: H Just Popped! in reply to IndianaRed, 07-23-2007 18:06:23
IndianaRed said: (quoted from post at 18:06:23 07/23/07) Hey Rusty, She's running!!!! This is the greatest day of my life! lol Not perfect yet, but running. I went back to the archives and searched on carb settings, just to make sure. Turns out I had the high speed adjust all the way in, starving apparently. Let her out and started right up. I didn't think that would affect starting that much, but it did. Feel like I'm learning book loads everyday.
Thanks again,
Brian
High speed setting matters since that is the start position of the throttle (well all I ever seen was, could be a oddball somewhere lol).
Take care of the carb, it can make your machine run great or be misserable not just starting but overheating, ruff restarts when hot, low power, poping, smoking oh the list goes on for out of whack carb settings.
One thing Ill warn ya about. Turn the gas off whenever she sits long period of time. Just onc eis all it takes to overflow carb, end up in crankcase thining the oil then seized block. Ya its happened to me. Not good feeling seeing a $900 engine sieze cause the float in carb stuck (unknown to me at time of course).
NawlensGator
07-24-2007 07:55:43
Dang dude!!
I know the feeling. It's called the agony and the ecstasy. Thanks for sharing and I know you'll take good care of it.
georgeky
07-23-2007 20:21:58
I sure am glad to hear it won't be going for parts. Have fun, and be careful.
IndianaRed
07-23-2007 20:33:55
 Re: H Just Popped! in reply to georgeky, 07-23-2007 20:21:58
Funny. Getting up this morning I thought there was no way she'd be running today. Tinker, tinker, tinker, Boom! Surprised me a lot.
Thanks George.
georgeky
07-23-2007 20:56:05
 Re: H Just Popped! in reply to IndianaRed, 07-23-2007 20:33:55
An old man that lives not to far from me always told me that patience and determination would prevail most every time. Congrats on a job well done.
RustyFarmall
07-23-2007 19:00:10
Yep, like I said, those carb adjustments and settings are not just a suggestion. They are critical. CONGRATULATIONS on getting the 'ol gal to run.
Mike CA
07-23-2007 18:30:53
Glad I could help.
Oh wait... nevermind. hehehe
I do want to see pictures of the old girl when she's all done!
IndianaRed
07-23-2007 18:56:22
 Re: H Just Popped! in reply to Mike CA, 07-23-2007 18:30:53
Dude, you need to deliver pizzas at night or something, whatever it takes to get yours. And just like I told ya, the longer it takes the better it feels when you get there. Just do it! :)
Pics to come.
Bri
Idaho Ron
07-24-2007 17:57:38
 Re: H Just Popped! in reply to IndianaRed, 07-23-2007 18:56:22
Man Am I happy for you. I have been reading this thread and was hopeing that you would get it. How about a big (WAY TO GO) You guys that helped him ROCK! Ron
