Farmall C engine/140
bigfutty
07-23-2007 16:33:13
I was given an engine out of a farmall 140 and was told that it was the same engine that was in a farmall C. i was wondering if this was true or not and if there was difference what they were. thanks
Bus Driver
07-24-2007 04:30:59
 Re: Farmall C engine/140 in reply to bigfutty, 07-23-2007 16:33:13
The Nebraska test of the C in 1948 shows that the C engine runs about 1650 RPM. The 140 is 1400 RPM. Some governor adjustment or swapping the governor might be necessary to get full power from the C.
Hugh MacKay
07-23-2007 19:01:10
It is the same engine, however there is a difference. The water pump on your Super is on the bottom engine block outlet. The water pump on the 140 is an automotive type built right into fan hub.
Just two weeks ago we had discussion on this, and if my memory serves me correctly there is a threaded hole somewhere in SC block for that setup, and that hole is not drilled in 140 block. It may be head and not block. I've forgotten exactly what this is.
To use the 140 water pump you may find problems with fan matching up to SC shroud and radiator. Not certain, however I do have both 130 and 140, there are differences, I've had both off but never at same time.
I think you best go to a parts book before you get too far into this.
georgeky
07-23-2007 20:06:28
 Re: Farmall C engine/140 in reply to Hugh MacKay, 07-23-2007 19:01:10
Hugh, I am not sure if he meant C or Super C, but they are a little different. Mostly in CI'c and the water pump as the C has doesn't have one.
rnicholas
07-23-2007 18:32:35
Oops. My bad. Forgot about the Supers. That's why they were supers, right?
rnicholas
07-23-2007 17:46:10
The 123 engine started with the 100. Not the C.
CNKS
07-23-2007 17:56:34
 Re: Farmall C engine/140 in reply to rnicholas, 07-23-2007 17:46:10
Super C and Super A1.
georgeky
07-23-2007 17:56:31
No it started with the Super C, and the last Super A's also had the 123 in them
georgeky
07-23-2007 16:41:22
No it is not the same. They are quite alike but do have some differences. The C has a 113 CI engine that is cooled by the thermal siphon system which has no water pump. The 140 has a 123 CI engine that has a water pump and a pressurized cooling system. They will fit in either tractor with minor modifications. The 140 engine will fit in your C and have a little more power.
