856D oil canister problem
D Glynn
07-23-2007 18:34:55
Was changing the oil filters on an IH 856D. After removing the canister, I pulled the oil filter out and poured the oil into a bucket. Not only poured oil out but a few parts, i.e. a spring base, a spring, and a retaining ring. Seems the retaining ring that holds the spring and spring base down in the center of the oil filter will no longer seat in the groove. Not sure if replacing the ring will work or the groove is worn to the point that it won't hold. Has anyone had this problem before and if so how did you fix it? Also, wondering if that spring base and spring could be left out. Seems that the base that the filter sits on is also spring loaded and serves to push the filter up against the top of the canister so the oil goes through the filter. Any help/comments/experiences would be appreciated. Thanks!
chuck46
07-23-2007 19:48:08
 Re: 856D oil canister problem in reply to D Glynn, 07-23-2007 18:34:55
Hi, Have not had that happen, but mine has 16,000 hours on, next time I will check them over good. Thanks for letting us know. Good luck, Chuck
No tools
07-23-2007 19:21:04
Yes just had that same on a 1456 this summer.
Was able to get new retaining ring clip and it did fit the grove fairly well.
Clean canisters.place bolt. then spring on bolt.next filter retainer. then retaining clip.
Ready to go back Together.
Bill
