Rings for 3 B
school teacher
07-24-2007 08:50:57
Help!! I somehow let water get in one cylinder and locked it.I got it loose but need new rings for it. It is the original 3 inch piston and I cannot find a source. I really only need them for the one piston, the rest are still in good shape. Can anyone tell me where I can get them? All I can find are for the overbore sizes.
Thanks
Bob
07-24-2007 09:42:21
 Re: Rings for 3 B in reply to school teacher, 07-24-2007 08:50:57
Hastings will sell you what you need (probably NOT cheap, though)!
Link
Also, try Dave Otto.
http://www.dol.net/~dave.reed/otto.html
Kendog
07-24-2007 09:37:33
ST- Email me at ken@superfetch.com. Maybe I can help you. -Ken
El Toro
07-24-2007 09:12:53
You can try an auto parts store like Napa to see if they can get just 3 piston rings. You will need the width of the rings or ring lans off the piston. You should run a glaze breaker thru the sleeve so the new rings will seat themselves. You should take a look at the rod bearings too.
My IH manual has the 2 compression rings width at .125" and the oil ring at .250". You need to double check these. Hal
PS: Some oil rings were .1875"
