Polarize gen. (H)
stevex
07-24-2007 09:04:44
My H manual say to make sure the H is positive ground before polarizing. It isnt positive ground. Do I need to do something different to polarize?
gene bender
07-24-2007 10:09:12
 Re: Polarize gen. (H) in reply to stevex, 07-24-2007 09:04:44
Check the regulator as sometimes they will say either pos or neg ground most replacements are labeled pos ground for the 6v systems
Bob
07-24-2007 09:39:38
Your tractor left the factory (+) ground.
It will function equally well with either ground polarity, so long as the coil (assuming battery ignition) is properly connected.
Set the battery polarity up the way you want it, then polarize the generator. The procedure is the same for either (+) or (-) ground... momentarily short the "BATT" and "ARM" terminals together at the regulator.
The point of the instructions is to be SURE the battery polarity is set up the way you want it BEFORE polarizing the generator OR starting the engine.
stevex
07-24-2007 09:43:01
 Re: Polarize gen. (H) in reply to Bob, 07-24-2007 09:39:38
Its fine the way it is. I will polarize it as it sits. I just wasnt sure if I needed to do it different due to the negative ground. You answered my question quite well. Thank you.
Bob
07-24-2007 09:47:43
 Re: Polarize gen. (H) in reply to stevex, 07-24-2007 09:43:01
Personally, I set up all my stuff (-) ground.
I know the "correct police" would be offended, but (+) ground is so rare these days people that might want to charge or jump-start a piece of equipment probably wouldn't even be aware to look out for (+) ground when connecting the cables.
Since there are no "purists" around my place, I feel there's less chance of error keeping everything (-) ground.
stevex
07-24-2007 10:08:15
 Re: Polarize gen. (H) in reply to Bob, 07-24-2007 09:47:43
My thoughts exactly. I dont see it as any different than the aftermarket three point I put on.
