Tow behind mower
Ed W
07-24-2007 17:30:22
Hello Folks. This question is not about tractors but tow behind mowers. Has anyone out there used a tow behind mower like a Swisher mower to cut a field of tall grass? I would appreciate your opinion. Thanks!
john d
07-25-2007 06:45:48
 Re: Tow behind mower in reply to Ed W, 07-24-2007 17:30:22
Swisher makes a nice 60" mower that will NOT do what you want. It belongs on the lawn, nowhere else. They also make a smaller mower, I think it's 44" or so, and it comes in a "rough cut" version that would mow taller grass.
glennster
07-24-2007 18:48:59
i have a swisher 60 inch trailing mower, 13.5 hp motor. works real nice, i tow it behind my farmall cub, that has a woods 59 inch belly mower. made an extended swinging drawbar so i can run the swisher in steep ditches and keep the tractor up on the road. snugged up it will cut just under 10 feet of grass in a pass.
T.B.W.
07-24-2007 18:02:03
Yes, it is a lawn mower and is made to cut grass that is no longer than you would let you lawn grow. I had one for a while to cut a pasture and it worked fine if I cut it every two weeks.
john cub owner
07-24-2007 19:05:23
 Re: Tow behind mower in reply to T.B.W., 07-24-2007 18:02:03
Bush Hog makes a pretty heavy duty tow behind, but the price is heavy duty also.
El Toro
07-25-2007 04:19:42
 Re: Tow behind mower in reply to john cub owner, 07-24-2007 19:05:23
I saw one of those Bush Hog mower's up in PA in Amish country being towed by 3 big mules. It sounded like a Wiscosin engine that we had on a baler. There was a young boy doing the mowing of corstalks. Hal
