Loose steering on Farmall A
Don F
07-24-2007 19:47:41
I am restoring a farmall A, the steering wheel will turn 1/2 turn and the front end don't turn ( the center arm doesn't move). I have the front end off the tractor and have the gearbox apart, the sector gear, the worm gear and the brass bushing seem to be good. I have ordered a new oil seal and gasket, Can anyone give me some help as to how to tighten up the steering. Many thanks in advance
Don F
07-25-2007 12:15:22
 Re: Loose steering on Farmall A in reply to Don F, 07-24-2007 19:47:41
Many thanks to Vern and Gene bender for your help I will try your sugestions.
gene bender
07-25-2007 04:09:48
The key in the gear needs to be checked aloso make sure both bearings are good. Replace the seals and i would replace the bushings as you have it apart. Get new gaskets and fill with 90wt should be ready to go. You didnt say if the out-put shaft has a tapered end or a square one.
Vern
07-24-2007 21:19:12
The most likely cause is that the arm is loose on the shaft. Some are square shafts with a clamp bolt thru the arm & some are a tapered shaft with a key & a nut on the end of the shaft.
Either way, tighten it up.
Vern
