Thinking about buy a Farmall 400. Pros/Cons?
Robert in KY
07-26-2007 15:29:36
I've been thinking about buying a Farmall 400 that is in pretty good shape. Runs good Hydo seems to be in good shape. Has a converted fast-hitch/three point hitch. Tin is straight. Price is 1400. Does anyone have any good or bad things they have had with a 400 before? Let me know!
Phil Smith
07-28-2007 15:21:35
 Re: Thinking about buy a Farmall 400. Pros/Cons? in reply to Robert in KY, 07-26-2007 15:29:36
I have owned a Farmall 400 for about seven years here in Kansas and use it regularly to run a 7' wide mower and disc. It has been a great tractor however just today, I heard some metallic knocking in the engine. Perhaps piston slap? I would recommend the tractor however, anyone out there have a recommendation for engine repair? Rebuild my own or go for a short block? Thanks.
georgeky
07-27-2007 10:19:12
Robert, the 400 is a real work horse. Capable of playing with a 3 bottom plow or 10 foot disc. Handle a 15 foot mower pretty good too. The worst thing is they do burn gas, but start good in cold weather. If it is as good as it looks where else could you get a tractor for 1400 that will do what the 400 will do. New riding mowers cosr a lot more than that.
Jason Simmerman
07-26-2007 20:57:45
If the rubber is good, motor is strong with good compression, good oil pressure while hot, decent clutch then why are you not there picking it up? If the TA is out, oh well. It makes it like the other 90% of those tractors that have a bad TA in em. If rubber holds air and is round and black it isn't that bad of a deal eithor really.
steve from mo - dangit!
07-26-2007 19:17:41
Good tractor, only made a couple years. Standard IH set of problems that probably were fixed many years ago on one that"s survived this long. Big one was the rear end bearings - the 400 has almost as much hp as a gas 560 if it has oversized high compression pistons.
Marc ON
07-26-2007 18:52:27
I'd love to have a 400/450 but never see them for sale up here in Ontario. For that price, I'd ask if he has a second or third one he's also willing to sell! But I'd make sure the TA is in good working condition first, I hear they can be expensive to fix or replace. Certainly is a heck of a lot cheaper than what folks are asking for a Super MTA!
Nat 2
07-27-2007 04:47:47
 Re: Thinking about buy a Farmall 400. Pros/Cons? in reply to Marc ON, 07-26-2007 18:52:27
For $1400, you can afford to fix the TA, and it's not that difficult or expensive to do.
Robert in KY
07-26-2007 18:22:59
 Re: Here's a pic fella's in reply to Robert in KY, 07-26-2007 15:29:36
third party image
Here is the tractor. Don't think I can say no to this one.
GordoSD
07-27-2007 04:31:17
 Re: Here's a pic fella's in reply to Robert in KY, 07-26-2007 18:22:59
That's a 2700 dollar tractor (minimum) here anyday anyway. If you don't want it I do. I'd be in the DOdge CTD in a heartbeat.
Gordo
Floyd352
07-26-2007 15:44:50
I ran one for 5 years WISH i STILL HAD IT [it was a friends] baled 2000 bales a year for myself and 1000 for the friend. price is good around here they bring2-3000
Larry808
07-26-2007 16:23:11
 Re: Thinking about buy a Farmall 400. Pros/Cons? in reply to Floyd352, 07-26-2007 15:44:50
I'd like to know where they bring 2-3000 ??
They are a great tractor I think 1400 is a very good deal . I had one a couple years ago , rebuilt motor and new torque . It took me almost a year to get 1600 for it .
Floyd352
07-26-2007 16:32:50
 Re: Thinking about buy a Farmall 400. Pros/Cons? in reply to Larry808, 07-26-2007 16:23:11
upstate NY around rochester. Cananadaigua to be sure. Saw them sell at an auction here in the spring 2 years ago. 3 went though low one 1900 top one 3000. low one didn't run. seen a couple others sell for same. wish I knew of yours. where are you selling.
Larry806
07-26-2007 18:39:53
 Re: Thinking about buy a Farmall 400. Pros/Cons? in reply to Floyd352, 07-26-2007 16:32:50
Central Ohio
