serial tags removed 685
karl f
07-26-2007 22:34:20
the road mowing rig (c-ih 685) we bought is missing the serial tag for the tractor. did they relocate this on those models (it would be covered by the mower frame) or did something stupid happen in the tractor's past?
engine and transmission numbers are still there.
there's a tag on the spinning grille screen unit, but i assume that is for the grille screen.
any advice is appreciated
karl f
Nat 2
07-27-2007 04:44:29
 Re: serial tags removed 685 in reply to karl f, 07-26-2007 22:34:20
Karl, my advice to you is to not worry about it. Once the serial number tag is gone, it's gone. Unless you can trace the tractor's history, AND the previous owner(s) still have the paperwork with the serial number listed, you'll never know what the original serial number was.
The mower manufacturer likely realized that the tag would be covered by the mower frame, removed it, and gave it to the dealer in an envelope with the instructions, "Keep this with the tractor."
karl f
07-27-2007 23:46:16
 Re: serial tags removed 685 in reply to Nat 2, 07-27-2007 04:44:29
the only problem is in the parts look up when they say before or after pin #.
otherwise i dont think it is an issue
