Behlen Road Gear on F20
ET
07-27-2007 06:47:33
I have recently finished the restoration of my wide front F20N. It is equiped with a behlen road gear. The seal on the input shaft leaks and it is a odd seal. It presses into the front cover and the rubber lip that contacts the yoke is quite long and cone shaped. Does anybody know a part number for this seal or where I can get one? Will a comon seal that matches the bore and shaft size work? I don't real want to pull the old seal out right now and destroy it because then I will be dead in the water without a replacement.
gene bender
07-28-2007 03:36:02
 Re: Behlen Road Gear on F20 in reply to ET, 07-27-2007 06:47:33
Take it apart and go to a auto parts store and they can measure and get a new one within 24hrs as you have to take it apart anyway to replace. You would only be torn down two days
Bob Kerr
07-27-2007 07:39:06
Go to a bearing house, They will either have or get the seal, or match a newer style to what you need. Better check your input shaft bearings also, the ones in my f-12 road gear are toast and the front seal leaked like a sieve.
ET
07-27-2007 08:29:17
 Re: Behlen Road Gear on F20 in reply to Bob Kerr, 07-27-2007 07:39:06
Thanks for the reply. My bearings are good I've had it all apart and could not find any numbers on the seal. I do have a good bearing and seal supplier but I hate to pull the seal and get stuck without one.
RustyFarmall
07-27-2007 12:11:31
 Re: Behlen Road Gear on F20 in reply to ET, 07-27-2007 08:29:17
I'd say just find a seal that fits the bore and shaft size and call it good.
