Schwartz tie rod ends
GordoSD
07-27-2007 17:16:36
I was tightening up the Schwartz front end on the SH yesterday. One of the tie rod ends seemed frozen. After removal and disassembly i found that the adjusting'cup' was bottomed out but there was still alot of end play, and some side play in that end.
Does anyone know if just the piece with the ball and stud is available? FOr now I placed a washer in between the stud and the cup and pressed it into a cup shaped shim on the hyd press. At least it's tight vertically now. And how about the rubber seals/boots? They are gone. Are those available without the entire end assembly?
Gordo
MN Scott
07-27-2007 19:20:29
 Re: Schwartz tie rod ends in reply to GordoSD, 07-27-2007 17:16:36
A&I aftermarket bought the swartz widefront end line and they carry parts for them. They also still manufacture new ones.
Chester5731
07-28-2007 06:11:25
 Re: Schwartz tie rod ends in reply to MN Scott, 07-27-2007 19:20:29
Do you have any contact info for A&I?
MN Scott
07-28-2007 06:59:39
 Re: Schwartz tie rod ends in reply to Chester5731, 07-28-2007 06:11:25
Here's the link for A&I.
Chester5731
07-28-2007 07:22:26
 Re: Schwartz tie rod ends in reply to MN Scott, 07-28-2007 06:59:39
Thanks!!!!
flying belgian
07-27-2007 18:22:32
I fixed mine the same way. The rubber boots are avail. at any auto parts store.I think I got mine from Napa
