300 vs 350 carb
Marty Schott
07-27-2007 21:01:19
Is there any difference in the carb off a 300 or 350 farmall?
Tim Shaw
07-28-2007 06:04:08
 Re: 300 vs 350 carb in reply to vtfarmer, 07-27-2007 21:01:19
Marty Schott said: (quoted from post at 23:01:19 07/27/07) Is there any difference in the carb off a 300 or 350 farmall?
I've got a carb off of a 300U on my Farmall 350. Both carbs had the same number on the small round brass tag.
D Slater
07-28-2007 06:02:57
 Re: 300 vs 350 carb in reply to Marty Schott, 07-27-2007 21:01:19
Most are the same gasoline carburetor # 361525 R92. 300 started out with 361525 R91 which has some differances but finished production with 361525 R92. IH quit selling the different parts for the 361525 R91 and instead started selling a carburetor change over package to change 361525R91 to a 92 type. They discontinued that kit after enough were made to cover all the R91 carburetors installed on tractors. You can still find some R91 carburetors on tractors that were never changed over though. Unless someones added the part a R91 carburetor didn't have a main metering jet adjustment screw and packing nut, instead just a plug screwed in hole.
Janicholson
07-27-2007 21:20:51
yes jetting, venturi size, and performance. all favor the 350. JimN
