Weight of international dozer
Marco54
07-28-2007 14:41:45
Can anyone tell me the weight of an International
340 Dozer with a 6 way factory blade and a small international factory backhoe?
Thanks,
Marco
Haas
07-29-2007 17:34:10
 Re: Weight of international dozer in reply to Marco54, 07-28-2007 14:41:45
I owned a TD-340 with 6 way blade for a short while. Easily hauled on a 14,000 lb goose neck trailer. The tractor alone is about 6000 lb as I recall with the 6 way blade adding another 1000 lbs or so. Don't know on the back hoe, but likely another 2000 for that so the total would be less than 10,000, still making it possible to haul on a gooseneck with an HD pickup.
TD340 Specs
07-28-2007 21:49:55
Here ya go.
Al L. in Wisc.
07-28-2007 15:36:55
 check Moose Lake, MN in reply to Marco54, 07-28-2007 14:41:45
If you check the photo ads, yesterday a fellow in Moose Lake, MN posted a TD-340 and he may have a good inkling - I think inkling in Moose Lake, MN is tolerated as folks probably mind there own business :^).
