Re: Parts Swap 806--460U
Larry in Mo
07-29-2007 08:32:00
Unless I'm missing something here your 3 pt adapter points should slide right out. There is a latch on the top of the fast hitch reciever tube that raises up to release the adapter. It may be rusty or dirty. Yes the adapter should fit your 460. LE
georgeky
07-29-2007 09:26:34
 Re: Parts Swap 806--460U in reply to Larry in Mo, 07-29-2007 08:32:00
Larry, I don't think he is talking about an adapter. He wanted to know about the telescoping lift arm sockets from a 3 point hitch. They will not work in a fast hitch socket.
Larry in Mo
07-29-2007 08:43:49
Butch; read your question again. If your 806 has factory 3 pt., the answer is no. If it is fast hitch then my above post is correct.LE
Butch WI
07-29-2007 09:13:29
 Re: Parts Swap 806--460U in reply to Larry in Mo, 07-29-2007 08:43:49
Larry, I guess I should have been more specific about the 806. It has A factory 3pt.
Sorry,
Butch
georgeky
07-29-2007 14:37:16
 Re: Parts Swap 806--460U in reply to Butch WI, 07-29-2007 09:13:29
Butch, they will NOT work. Made completely different. Just measure the width and you will find the fast hitch socket is wider than the socket on the 3 point arms. They are also different on the part you can't see.
