farmall H
sam in mo
07-29-2007 12:50:23
Can anyone tell me how to plum a H belly pump to make a hydrolic clinder work both ways ( pressure up and pressure down) ? Thanks Sam
akb
07-29-2007 23:19:29
 Re: farmall H in reply to sam in mo, 07-29-2007 12:50:23
The return line from the valve has to go to a tee fitting installed in the drain hole of the belly resevior.If you go into the vent pipe it will eventually blow out the top even with a 3 foot extention.Been there done that.
Janicholson
07-29-2007 13:06:45
third party image
Hear is a very simple diagram, the parts are available at a Tractor friendly store. The hose into the top of the filler (using a new T fitting) can also be plumbed into the bottom grain plug with a T fitting. Use hydraulic qualified hoses, and an open center valve. Use a small clamp on the control rod to keep it from going in while using the system. good luck. JimN
