39 H Engine
Paul G. in Mn
07-29-2007 13:51:05
I tore into the engine on the 39 H I bought last weekend. It was stuck so I pulled the head and to my suprise things looked really nice inside. I just had 1 piston that was stuck so went to work on it but while I was pressing on it I had the sleeve break. I was able to get the sleeve and piston out and was able to get the piston out of the sleeve. Looking how nice this is inside I would kinda like to reuse the pistons, just add new rings and rod bearings. Is it possible to get by with putting in 1 sleeve either new or used or would I be asking for trouble? This tractor will be painted up and maybe used very lightly for no more the 10 hours a year so really not sure I want to spend the money on a full rebuild kit. Any thing else I should be looking at while I have things apart? Thanks Paul
akb
07-29-2007 23:10:56
 Re: 39 H Engine in reply to Paul G. in Mn, 07-29-2007 13:51:05
Over bore on the H is 3 7/16
Paul G. in Mn
07-30-2007 16:52:45
 Re: 39 H Engine in reply to akb, 07-29-2007 23:10:56
I meassured my pistons and they are 3 7/16
georgeky
07-30-2007 06:08:17
akb, you are certainly right. I must have had m kits on my mind as they go a whole 1/8 at a time.
tom windsor
07-29-2007 21:19:13
and, I have 2 complete 3 3/8 sleeves, rings and pistons. Would like to move them because I am 2 short!
tw
IndianaRed
07-29-2007 18:17:45
Paul,
I've got 3 good used original sleeves out of my 42 H. You can have one or all three for cost of shipping if you want.
Brian
georgeky
07-29-2007 14:48:35
Paul, you could do that if you can find a sleeve. They are sold in matching set with pistons,rings and pins. You may want to measure the bore and see if it is stock. 3 and 3/8 is the stock bore if it has over bore pistons which many do it will be 3 and 1/2 inches. If it has standard bore you may want the new over bore sleeves and pistons, as they add quite a bit of power to them. Making it the same displacement as the Super H. I do reuse all my pistons at overhauls because I have all IH fire craters or M&W's that can't be bought new anymore. If you can find a good used sleeve it will work, but check it out good before installing it as it could be trash. To each his own, but if I had it down I would go with all new over bore sleeves and it will outlast you when finished.
