Drippy F-12 fuel pump
Pete in Holland
07-29-2007 14:18:29
Guys -
At a show last weekend, my F-12 started dribbling fuel out the funnel-shaped breather on the front of the pump. Engine runs fine, just that the breather drips fuel now.
Can I assume the diaphram has gone south? What parts are needed to rebuild the pump and are there any things that I need to be aware of?
Thanx..... ... Pete
James Williams
07-29-2007 17:17:23
 Re: Drippy F-12 fuel pump in reply to Pete in Holland, MI, 07-29-2007 14:18:29
Gary,F12 pumps are very simple,There are 2 different kinds,one has small square disc in them that are check valves.The most common are 2 brass check valves.Some of the pumps come with a diaphragm that can be replaced.others you need to order the more expensive kit that has a new diaphragm made on the shaft.Rice equipment has what you need.
jimmy 304-582-9995
Pete in Holland, MI
07-30-2007 09:55:27
 Thought so. Many thanks ! Pete in reply to James Williams, 07-29-2007 17:17:23
