INTERNATIONAL 284
Richard Heath
07-30-2007 07:45:52
A friend of mine bought an International 284. He cannot get it to shift from high range into low range. Any ideas? Can the lever freeze up if never put in low range for many years or is it an internal prfoblem?
Nat 2
07-30-2007 14:16:18
 Re: INTERNATIONAL 284 in reply to Richard Heath, 07-30-2007 07:45:52
Unfortunately, like most tractor problems, there is no way to really know. Any response would be a blind guess and could send you on a wild goose chase, tearing the tractor down and spending $1000's on parts, only to discover that something else is wrong.
What you need to do is approach the problem systematically: Does the lever wiggle? When the lever wiggles, does the linkage move? When the linkage moves, where does it go? When you follow the linkage into the transmission, does it wiggle there? If that's all loose, you need to get a service manual and start digging into the shifting mechanism in the transmission.
