Hydraulic pump kit
Joe Kimbriel
07-30-2007 14:28:59
Any idea where to get a rebuild kit for a 360687 r91 hydraulic pump? I can't find this pump part number listed anywhere. The seal is 98-212 CR and it leaks oil into the engine block.
Thanks,
Joe
RedNeckSuperC
07-30-2007 22:48:01
 Re: Hydraulic pump kit in reply to Joe Kimbriel, 07-30-2007 14:28:59
Mine must be the Thompson because I have a "o" ring that seals the shaft where it goes thru the cover and it leaks there. My first one was shot and I couldnt find one the right size to replace it so I made one but didnt get it right either because it got too hot and distorted and leaked the oil out again. Shaft is still good after the last repair job. I just need the correct "O" ring.
Any idea where a guy could get one?
georgeky
07-31-2007 07:14:20
 Re: Hydraulic pump kit in reply to RedNeckSuperC, 07-30-2007 22:48:01
There are 3 kits available. One for Pesco,Cessna and Thompson. Brad has them in stock at 1-888-824-0544. He probably has just the o ring as well, but I didn't ask him that. Just give him a call and he will fix you up. He will need the number off your pump.
RedNeckSuperC
08-01-2007 15:00:02
 Re: Hydraulic pump kit in reply to georgeky, 07-31-2007 07:14:20
How do I tell what make of pump it is>
I dont see a name on it, just numbers
riverbend
07-30-2007 20:54:49
What brand of pump is it ?
My SC has a pump no. 384 508 R90. It is a Cessna pump from a 130 or 140. Your IH dealer should have a 'where used' listing for it. The kit for my pump was nla from IH. An old Cessna distributor in Washington state had the kit.
Greg
gene bender
07-30-2007 16:50:40
There is two types of seals that were used take your pump off then you will know which type you need along with a speedy sleeve if the shaft is worn. Any parts house can get the seal or o-ring which ever you need assuming that you have parts man and not a part time dummy.
El Toro
07-30-2007 16:08:10
third party image
This parts breakdown should cover your hydraulic pump. You need to check the shaft where that seal
rides. It may have worn a groove into the shaft.
Speedi-sleeves are available to cover that surface.
Hal
Joe Kimbriel
07-31-2007 06:57:09
 Re: Hydraulic pump kit in reply to El Toro, 07-30-2007 16:08:10
Thanks, Hal. Thats it exactly.
El Toro
07-31-2007 07:11:16
 Re: Hydraulic pump kit in reply to Joe Kimbriel, 07-31-2007 06:57:09
If you have a problem getting a repair kit call 1-800-732-0017 and ask for farm tractor parts. Hal
georgeky
07-30-2007 14:35:16
What does it fit?
Joe Kimbriel
07-30-2007 14:38:39
 Re: Hydraulic pump kit in reply to georgeky, 07-30-2007 14:35:16
I can't read the serial number but it is a super C with big brakes. The casting date code is "T".
Hope that helps,
Joe
georgeky
07-30-2007 14:44:00
 Re: Hydraulic pump kit in reply to Joe Kimbriel, 07-30-2007 14:38:39
Joe, those kits can be had from IH. If you don't have one in your area call Brad at 1-888-824-0544. He has them in stock and will mail it to your door. I am curious as to what you mean by big brakes? If it has band type it is a plain old C instead of Super C. I think T would make it a 1950 C.
Joe Kimbriel
07-30-2007 14:56:53
 Re: Hydraulic pump kit in reply to georgeky, 07-30-2007 14:44:00
The big brakes are compared to the Super C that I have. Your probley right and it's just a plain C. It's my neighbors and he can't remember what it is. Oh well, Thanks and I'll call Brad. The pumps that I saw had springs in them and this one does not.
Thanks,
Joe
georgeky
07-30-2007 15:06:00
 Re: Hydraulic pump kit in reply to Joe Kimbriel, 07-30-2007 14:56:53
Just give Brad that part number and he will fix you up. There seems to be lots of C's with Super C decals on them. If it has band brakes, straight clutch and brake pedals and the gas tank sits almost on the touch control box it is a C.
