tandem vs. open center valve
rret
07-31-2007 06:05:35
looking at a Prince 2-spool control valve for my 2400A (Ag 454 equivalent). The valve has "tandem" center spools - are these equivalent to open center valves (which my tractor requires)?
Owen Aaland
07-31-2007 12:46:40
 Re: tandem vs. open center valve in reply to rret, 07-31-2007 06:05:35
Tandem means that it is a two spool valve, able to run two cylinder independently. It may be either closed center or open center. Some are convertable by changing a plug in the valve body.
Janicholson
07-31-2007 12:06:42
If you can blow through the inlet, and it comes out the outlet, it is open center. JimN
