sjh-(manifold)
D Slater
07-31-2007 12:40:36
I posted 4 pictures of gasoline type manifolds in parts and pieces, heading M type, M&SM type, 400 type and 450 type so you can look to see if there's a match for yours there. The M type is partly covered by hood but I think you can get a idea of shape. All of that type won't look exactly the same but have same general shape. Most change in it was when IH went from 3/8 to 7/16 studs in head for manifold mounting. M,SM type from late M tractors had a little bigger ID intake runners and was used through MTA and maybe a few early 400 tractors. 450 type was last gas type that I know of. Depending on what years or what stock IH had in the system any of the later manifolds could be purchased for replacement use on M,SM,400 tractors. Early types were discontinued and at one time instructions were furnished to change 3/8 studs in early heads to 7/16 size.
