350 clutch wont disingage
Old Hank
08-01-2007 04:46:58
my 350 syddenly refused to disengage while
going in reverse.
Now I can only shift when engine is not running.
Wats the cause and whats the fix?
georgeky
08-01-2007 08:36:48
 Re: 350 clutch wont disingage in reply to Old Hank, 08-01-2007 04:46:58
The cover that Nat mentioned is on the bottom.
Nat 2
08-01-2007 08:29:06
There could be a dozen causes. Lots of stuff can go bad in there.
Doubtful that the clutch rusted to the flywheel, but that does happen.
The clutch could simply be out of adjustment. Have you tried adjusting it lately?
Something may have broke, including the throwout bearing, or maybe even the release lever on the shaft. Does the pedal feel different?
Without more information, any guess is just a that, a guess. Could be right. Could be an expensive wild goose chase.
Farmall 350? Can't remember if there's a cover on top or on on the bottom, but it may behoove you to check for one, and remove it if you do find it.
georgeky
08-01-2007 05:51:13
Maybe, the throw out bearing is shot. If so you will have to split the tractor and install a new one.
