966D TA
Seeing Red
08-01-2007 10:23:20
I have a situation with the TA on my 966. It will go fine in TA and does not slip at all, but when the handle is in direct it acts like it is in neutral for a few seconds then jumps into direct. Is this an adjustment or a split and new TA situation? Sometimes it takes a while for it to get to direct, but then seems to work ok after that.
The tractor vet
08-01-2007 19:37:51
 Re: 966D TA in reply to Seeing Red, 08-01-2007 10:23:20
Well with out putting the gauges to it and checking all the linkage and make sure that the selector valve is going ALL the way up and all the way down TO THE SNAP Ring against the nut there could be a BIT more wrong then the previous post said . as he is just looking on the net and probably never done a T/A in his life but yet want to Sell you some parts. If it comes down to the fact that ya need to replace the T/A then do yourself a favor and put one in that has a warranty on BOTH parts AND LABOR . Myself i have always used Hy Capaicity and for 19 years with all that i have installed NEVER had a bad one as it only costs a dollar more to go first class.
Kevin Meier
08-02-2007 14:04:30
 Re: 966D TA in reply to The tractor vet, 08-01-2007 19:37:51
I build over 1100 ta's a year hydraullic and have built just over 2200 mechanical. I also do installations. Please don't accuse me of trying to rob people on here. I am very familiar with Hy cap torques also and have warranty just the same. But thanks for asking me out right personally before accusing me of anything tractor vet. I guess i can learn more from you than I first expected. thanks so much.
Kevin Meier
08-02-2007 14:41:22
 Re: 966D TA in reply to Kevin Meier, 08-02-2007 14:04:30
I forgot to add that my boss used to own hy capacity and has improved all of our clutches, t/a's water pumps and several other parts. I hope this gives me enough background to help people out. I am really interested in all info that you give tractor vet so please don't get me wrong. I am trying to get into hydro stat transmissions also vet...so if ya could help me out there please do?
Kevin
Kevin Meier
08-01-2007 13:56:01
You should check all of your hydraullic pressures first. I also found this info on a web site SLIPS ON HIGH SIDE (DD) OF TA. A. SELECTOR SPOOL NOT ADJUSTED PROPERLY. A. ADJUST SELECTOR SPOOL.
SPECIFICATION. B. LOW OR LOSS OF CLUTCH PRESSURE. B. ADJUST CLUTCH PRESSURE TO CORRECT C. DUMP VALVE STUCK OPEN OR MISADJUSTED C. CHECK OR ADJUST. D. CLUTCH PACK WORN OUT. D. REPLACE TA. I also have all parts you would need to replace the t/a if interested send me an email. Hope this helps.
