Where can I find cam info?
Farmall MD
08-01-2007 15:25:28
I think I might have gotten the cam gear straightened out. But to make sure I was wondering where I could find the cam degree info, or if someone with a good manual has it.
What I'd like to have is:
Int valve opens @ ? degrees before TDC
Int valve closes @ ? degrees before BDC
Exh valve opens @ ? degrees before BDC
exh valve closes @ ? degrees before TDC
If this information even exists. It should, I just don't know where. Thanks, Doug
Owen Aaland
08-01-2007 19:29:48
 Re: Where can I find cam info? in reply to Farmall MD, 08-01-2007 15:25:28
15, 35, 42, 10
Lever clearance for timing .013
Farmall MD
08-02-2007 01:21:05
 Re: Where can I find cam info? in reply to Owen Aaland, 08-01-2007 19:29:48
Owen, thanks a million. Thanks, Doug N
Farmall MD
08-01-2007 15:31:46
Sorry, I should've mentioned it's an F-12. Doug N
