1066 trans
ih460puller
08-01-2007 21:46:00
Which pump supplies the range and speed trans on a 1066
Owen Aaland
08-01-2007 22:34:05
 Re: 1066 trans in reply to ih460puller, 08-01-2007 21:46:00
The MCV pump provides the lube for the transmission and differential. Transmission is lubed by the TA lube circut. The differential is lubed by the return oil from the oil cooler. Bottom shafts are lubed by being below the oil level.
ih460puller
08-02-2007 18:24:57
 Re: 1066 trans in reply to Owen Aaland, 08-01-2007 22:34:05
I am building a puller, can I remove the pto pump and the pump for the hyd lift and be okay?
Owen Aaland
08-02-2007 22:07:10
 Re: 1066 trans in reply to ih460puller, 08-02-2007 18:24:57
The PTO is a self contained unit with the pump and clutch all contained in the PTO unit. The rear hydraulic pump provides oil for the hitch and auxialary valves only.
Oil from the hitch pump was never used for lubrication of any of the transmission or rear end. There is always a posibillity of contamination in the oil returning from the auxialary valves so you would want that oil to be filtered before it was sent to any bearings.
