What is this behind carb?
Mike CA
08-02-2007 00:08:57
I've never seen one of these before. What is that brass looking thing behind the carb?
third party image
Andy Motteberg
08-02-2007 16:00:27
 Re: What is this behind carb? in reply to Mike CA, 08-02-2007 00:08:57
There is supposed to be a petcock in there, but it does not look like that. It is not a JD petcock.
Mike CA
08-02-2007 10:34:56
Ok, so it's a coolant drain. Thanks. That goes in line with what the owner told me about the radiator drain. This tractor came from Eastern Washington, and they drained teh coolant daily after work to prevent the engine from cracking during a freeze. So they added a quicker radiator drain... and apparently they added this block drain as well.
What should go there? I don't think I'm going to keep that pet-cock on there.
Steven@AZ
08-02-2007 10:58:26
 Re: What is this behind carb? in reply to Mike CA, 08-02-2007 10:34:56
Originally had one of those plugs with the wings on it so you could remove it by hand. OEM Tractor Parts has them...
old
08-02-2007 09:36:32
That be a drain for the block. Open it up to drain coolant out of the engine block. It doesn't look stock so some one probablty added it at so point
Allan In NE
08-02-2007 04:22:43
Hi Mike,
That's a pet-cock.
All the old 2-pop John Deeres used to have 'em installed in the cylinders to release the compression.
Allan
old
08-02-2007 09:37:55
 Re: What is this behind carb? in reply to Allan In NE, 08-02-2007 04:22:43
Allan not all the JD 2 cylinder tractors have those. My 1035 JD-B doesn't have them never has and never will have them
dcw
08-02-2007 02:50:22
That is the block drain.Someone has a brass petcock in it.
Farmall MD
08-02-2007 01:09:14
Looks like a water drain. Doug N
GeneMO
08-02-2007 05:56:25
 Re: What is this behind carb? in reply to Farmall MD, 08-02-2007 01:09:14
My dad told of always draining the water during cold weather as they never ran anti-freeze. Looks like someone wanted to speed up the process and installed a petcock.
Anti-freeze must not have come into wide spread usage until the 50's or there abouts.
Gene
