Is this grill toast?
Mike CA
08-02-2007 00:17:03
I didn't even notice it when I first was looking, but now I see what this H doesn't have a grill insert. The bottom portion has been ripped away. Other than this, the grill is near perfect! Is it done for, or can this be repaired well enough to look like new? (not by me, of course)
third party image
flying belgian
08-02-2007 18:02:03
 Re: Is this grill toast? in reply to Mike CA, 08-02-2007 00:17:03
I run a metal Fab shop and I could easily repair that for you. I'm sure you have a local fab shop that could do you a nice job.
Steven@AZ
08-02-2007 10:57:07
Any decent body shop should be able to repair that for a reasonable amount if you find them an example of what it is supposed to look like and a replacement insert... Maybe find a trashed grille to cut the lower piece out of to replace what's missing?
Jimmy King
08-02-2007 03:23:31
Mike, there was an arm fastened to the bolster there. It was for the culitivater so when you turned the culitivater would shift and not plow up corn, milo, sorgo. or what ever you were culitivating.
Mike CA
08-02-2007 10:53:22
 Re: Is this grill toast? in reply to Jimmy King, 08-02-2007 03:23:31
Jimmy King said: (quoted from post at 03:23:31 08/02/07) Mike, there was an arm fastened to the bolster there. It was for the culitivater so when you turned the culitivater would shift and not plow up corn, milo, sorgo. or what ever you were culitivating.
Yes, but the bottom strip of metal was there. It has been ripped away on this grill.
I'll ask if he may have it, but I seriously doubt it.
dcw
08-02-2007 02:49:13
That grille can be fixed easily,if this is all thats wrong with it.Wish the grille on my M was as good!
