Name this control
Mike CA
08-02-2007 00:25:49
Anyone have any idea what this is for? It's sitting on the '44 H and is hooked to the hydraulic pump.
third party image
skk
08-02-2007 20:32:05
 Re: Name this control in reply to Mike CA, 08-02-2007 00:25:49
I'm interested Mike. Been looking for a good serviceable one.
Mike CA
08-03-2007 00:02:57
 Re: Name this control in reply to skk, 08-02-2007 20:32:05
skk said: (quoted from post at 20:32:05 08/02/07) I'm interested Mike. Been looking for a good serviceable one.
Send me an e-mail
skk
08-03-2007 19:38:45
 Re: Name this control in reply to Mike CA, 08-03-2007 00:02:57
How about you send me an email since your's is not listed??? Pictures from all angles good too!
skk
Andy Motteberg
08-02-2007 15:54:59
If you are not using that hydraulic valve, put it on eBay and you might get $150-$200 for it. I've seen them go over $200 before.
Steven@AZ
08-02-2007 10:55:34
Liftall selector valve... bring at least $100 to $150 on eBay. Not good for much other than cultivators you want to lift/lower separately.
Wardner
08-02-2007 07:39:48
I have several of those valves. They are used on two or more single acting cylinders.
One application would be on cultivators where you wanted to lift one side but not the other. The center slot allows both sides to elevate at the same time.
The valve cannot be used on double acting cylinders without additional aftermarket valving.
Mike CA
08-02-2007 10:47:16
 Re: Name this control in reply to Wardner, 08-02-2007 07:39:48
Wardner said: (quoted from post at 07:39:48 08/02/07) I have several of those valves. They are used on two or more single acting cylinders.
Is it worth anything Wardner? I don't really believe I will be using it. Maybe someone around here could put it to work.
dcw
08-02-2007 02:47:32
According to my parts book,that is a selective lift control.It allows you to select between two hydraulic circuits or more from one valve,like the lift cylinders and tip cylinder on a loader.No need then for several levers.
