Basket Case H sleeves are out!
neblinc
08-02-2007 05:57:54
third party image
Well I am finally done with the engine at this point. Now it goes to the machine shop to check for cracks before I start spending any money for a complete rebuild.
I am figuring on close to $700 just for parts and $250-$300 for the machine shop to do the head. Still need them to give me a quote on the block.
More pics on the link below.
Randy
Tom Windsor
08-02-2007 22:27:15
 Re: Basket Case H sleeves are out! in reply to neblinc, 08-02-2007 05:57:54
One more queston, How many head bolts did you break getting them out? :-)
t
Tom Windsor
08-02-2007 22:24:37
That is one cool puller. How abut taking it out of there and take a picture of the complete thing so I can gosee if I can make one.
TW
neblinc
08-03-2007 05:19:23
 Re: Basket Case H sleeves are out! in reply to Tom Windsor, 08-02-2007 22:24:37
Hey Tom
This puller is made by OTC and I think they still make them. You can download a pdf of their catalog.
I can try and get some pics nect time I am over at the neighbors shop.
Randy
skk
08-02-2007 20:28:56
I've just got to get out there and visit with you. Since you are so experienced now, I've got that M block with the four.....
Bus Driver
08-02-2007 14:48:31
Enjoyed the pictures!
Mike CA
08-02-2007 10:42:47
Thanks for the updates Randy!
onefarmer
08-02-2007 09:20:33
The flywheel holes are for balancing and the groove in the crank pumps the oil that gets into the felt seal back into the engines.
DelMN
08-02-2007 07:05:57
Nice pictures!! The extra holes in the flywheel were for balancing--I think.
MN Scott
08-02-2007 06:04:43
Also budget having the machine shop rebuild the connecting rods. Very important to have new wrist pin bushings installed and fitted and the large ends resized.
neblinc
08-03-2007 05:21:15
 Re: Basket Case H sleeves are out! in reply to MN Scott, 08-02-2007 06:04:43
Hey Scott, what do you mean by the large ends resized?
I see that the wrist pins come with the rebuild kits, but not sure about your meaning.
Randy
MN Scott
08-03-2007 11:48:55
 Re: Basket Case H sleeves are out! in reply to neblinc, 08-03-2007 05:21:15
After 50+ years of use the large ends will tend to get a bit egg shaped. This makes proper clamping of the bearing difficult. Gas rods are not as critical as diesel rods but they should be measureed by a machinist. I just ovehauled a Super H and the big ends were way out of round. To fix them the machinist cuts a little metal from the mating surfaces of the rod cap and rod and then rehones the bore to a perfect circle to original specs. Like I said you can most likelly get by not doing it with low rpm gas engines but why take the risk of spinning a bearing and the machine shop has to install and fit the pin bushings anyways. A bit of advice don't try to install the pin bushings your self. They have to be fitted to the piston pin and honed parall to the rod using a special machine.
