Date of 15-30
Larry Kastens
08-03-2007 12:46:21
What is the date of manufacture for a McCormick 15-30 with a serial number of 1G80994? My tractor serial number book doesn't list anything with that high of a number for the 15-30? It has a brass carburetor and a flat pulley for the fan and crankshaft pulley.
Thanks.
Hoss in Maine
08-04-2007 11:35:34
 Re: Date of 15-30 in reply to Larry Kastens, 08-03-2007 12:46:21
Git on your creeper and roll under it and look between clutch and tranny on main casting will be a build date,
steelfronts
08-03-2007 13:32:43
Larry the prefix is TG 64401 to TG99925 is 1928
Dick in NY
08-03-2007 13:19:05
Larry,
My data books don't show that low of a serial # for the 15-30 The chassic and engine prefix was TG and the serial #'s started at 99926 in 1929 and ended at 157447 in 1934. Dick
K-Mo
08-03-2007 17:15:11
 Re: Date of 15-30 in reply to Dick in NY, 08-03-2007 13:19:05
The serial number range you mention are referred to as the 22-36. Although it is my understanding IH never used a 22-36 decal and they were all decalled with 15-30. The engine has a larger sleeve bore that tested 22HP & 36HP in the Nebraska Test. I believe these also have a V fan belt instead of the flat belt. At least this is the case on my 15-30 and 22-36.
K-Mo
moseed
08-03-2007 13:34:19
Mine is serial # TG 63595 and it's a 1927. You are probably sitting on a 1927 or 1928.
