Injector Pump For 826
Redstovebolt
08-04-2007 13:20:04
Hey,I got an 826 thats leaking juice out the side of the pump,power is down and has been hard to start ever since I got it...I hope somebody can tell me where I can get a good remaned pump....I believe it's an American Bosch EPVA Thanks,Tom
Redstovebolt
08-04-2007 18:42:06
 Re: Injector Pump For 826 in reply to MN Scott, 08-04-2007 13:59:08
Thanks Scott.....will their pump do as good a job I wonder. Thanks,Tom
MN Scott
08-05-2007 07:24:35
 Re: Injector Pump For 826 in reply to Redstovebolt, 08-04-2007 18:42:06
If your referancing the Stanadyne pump, starting will be easier because the Stanadyne pump is a modern pump with higher starting fuel pressure. As for power it will be the same as the bosch as you can set the fuel or power level on a dyno just like the bosch pump. Fuel useage may be a bit higher but really a nonissue. It all comes down to do you want to keep the tractor all original or do you want to get it running good for the lowest cost? You might be able to have your pump rebuilt to for much less than $2000 if it dosent need many high $ parts. Give a few pump shops in your area a call and see what they say. As for the Worthington reman pumps I have never bought one from them but I would think they are high quaility and they would stand behind them. The Stanadyne pump in the kit is new so no question there and I have installed one on a 756D and I'am happy with how it turned out.
Wisconsin Cowman
08-04-2007 13:33:22
 Re: Injector Pump For 826 in reply to Redstovebolt, 08-04-2007 13:20:04
Case Ih would have one or get it rebuilt.
Redstovebolt
08-04-2007 18:44:50
 Re: Injector Pump For 826 in reply to Wisconsin Cowman, 08-04-2007 13:33:22
Thanks Wis.....I been checkin' out different sites Tom
