Assistance needed with sickle bar mower...
tfringo
08-05-2007 07:52:07
Hi, I am working on a farmall c-21-P sickle mower. Specifically, I am looking for either a new or good used outer shoe for the bar. Part number on the shoe will either be a 455 558 R11 or it could be a version of MB 729 or MF 729. It uses 2 plow bolts to attach it to the bar. I believe the same or closely similar shoe was used on several types of mowers. If anyone can direct me to where I might find one, that would be super great. Thanks, Terry email is tfringo@aol.com
bil b va
08-06-2007 10:31:10
 Re: Assistance needed with sickle bar mower... in reply to tfringo, 08-05-2007 07:52:07
tractor supply can order the shoe for you . picked up mine today $21.33 plus $4.oo shipping . i sent you a E mail .
Jimer
08-05-2007 09:25:40
I have a P1F 729 laying in the garage. Looks the same as the 455 558 R1 on my mower. If interested let me know.
Jimer
08-05-2007 11:33:01
 Re: Assistance needed with sickle bar mower... in reply to Jimer, 08-05-2007 09:25:40
I just reread your post and mine, then went to the garage and looked at the # again. The correct number on the one in the garage is MP 729. Again, let me know if interested.
tfringo
08-05-2007 13:38:05
 Re: Assistance needed with sickle bar mower... in reply to Jimer, 08-05-2007 11:33:01
Yes, I would be interested. Make sure it is identical the the 455 558 R11 that you have. It must have the two bolt holes to attach it to the bar. Needs to have some life still left in it. Any chance I can call you or get a picture of it? Thanks, Terry tfringo@aol.com
Jimer
08-05-2007 13:10:31
Good grief, I can't walk and chew gum. The # on the spare one is MF 729!!!!! !!
NawlensGator
08-05-2007 08:50:32
I needed a frame (the shoe hinge that the drive pulley housing bolts to) for a IH 1300 sickle mower. Posted an add on the classifieds (upper left of page)and got an e-mail from someone who had one. It's now in my electrolysis tank getting cleaned up. Also try Hoober Inc in PA. Ph # 800-732-0017 ext 2365. They aren't cheap, but they have parts.
tfringo
08-05-2007 08:52:16
 Re: Assistance needed with sickle bar mower... in reply to NawlensGator, 08-05-2007 08:50:32
Thanks! I will have some calling to do on Monday. Terry
tfringo
08-05-2007 08:52:16
georgeky
08-05-2007 08:45:59
IH still sells them.
tfringo
08-05-2007 08:50:21
 Re: Assistance needed with sickle bar mower... in reply to georgeky, 08-05-2007 08:45:59
Hey, I will check into that on Monday. Do you know if it has a part number change? Thanks, Terry
georgeky
08-05-2007 08:58:07
 Re: Assistance needed with sickle bar mower... in reply to tfringo, 08-05-2007 08:50:21
No I don't know about the number. Call Brad he does and has them in stock. 1-888-824-0544
tfringo
08-05-2007 09:04:45
 Re: Assistance needed with sickle bar mower... in reply to georgeky, 08-05-2007 08:58:07
That is a big help. If I can find a new one that would be great. They tend to get a lot of wear and when they get really worn, they tend to catch grass behind/between the gards. Then it seems they drag a clump of grass around. Thanks again, Terry
