460 vs. 560
Eric W
08-05-2007 08:52:34
What are the physical differences between 460 and 560? Size, weight, axles? Would any 6 cyl IH gas motor fit in either one?
sd pete
08-05-2007 17:36:13
 Re: 460 vs. 560 in reply to Eric W, 08-05-2007 08:52:34
Rear end on the 460 is about the same as a 300 and the 560 differential is about the same as 400- 450. The 560 is a lot heavier tractor than the 460. The 460 came of the H line and the 560 came from the M line.
DennyF
08-05-2007 11:20:07
An uncle who had farmed 200+ acres from the 1940s-on with an H and an M, bought a 460 to add to the herd in the mid-60s. Didn't keep it long, swapped it for a 560 gasser WFE and was a happy ol' boy for the rest of his career.
Fairly subjective appraisal on his part, but he thought that 460 gasser was the most worthless tractor ever to wear red and white. Fergit if the 460 had TA, know the 560 did.
the Unforgiven
08-05-2007 18:02:26
 Re: 460 vs. 560 in reply to DennyF, 08-05-2007 11:20:07
I have to agree with your uncle, the 460 gas was a nice handy tractor, it just wouldn't pull a load.
DennyF
08-05-2007 21:14:14
 Re: 460 vs. 560 in reply to the Unforgiven, 08-05-2007 18:02:26
I learned to agree with him at a tender age. Saved me lots of tender spots on my head and backside. ;o)
Know it broke his heart the day he sold that 560, but after he sold his dairy herd and "retired", didn't really need it anymore. He monkeyed around raising/selling holstein heifers until well into his 70s, went back to farming with his H and M.
Cousin did all of his dad's baling with his 656D after the 560 went, still does on the same place.
jpl
08-05-2007 11:11:31
you should
georgeky
08-05-2007 08:56:37
They both came from factory with IH gas or diesel 6 cylinder engines.
Eric W
08-05-2007 09:09:23
 Re: 460 vs. 560 in reply to georgeky, 08-05-2007 08:56:37
Not concerned with what came from the factory. Want to know what can be done.
supermpuller
08-05-2007 12:20:32
 Re: 460 vs. 560 in reply to Eric W, 08-05-2007 09:09:23
You can drop a gas 301 out of a 806 or 715 combine in either a 460 or 560
Eric W
08-05-2007 13:48:52
 Re: 460 vs. 560 in reply to supermpuller, 08-05-2007 12:20:32
Are the axles and rear end the same. Does the 560 weigh more? Physically bigger in any way than the 460?
CNKS
08-05-2007 17:48:14
 Re: 460 vs. 560 in reply to Eric W, 08-05-2007 13:48:52
Compare the size difference of an H/SH/300/350 and M/SM/SMTA/400/450, relate that to the difference between a 460 and 560. In simplified terms a 460 is a 6 cylinder 350, a 560 is a 6 cylinder 450. Unlike the H and M blocks, the 460/560 blocks are the same and differ mainly in bore and stroke, not physical size like the H and M engines.
Owen Aaland
08-05-2007 18:05:15
 Re: 460 vs. 560 in reply to CNKS, 08-05-2007 17:48:14
The 460 qnd 560 have the same bore. Only the stroke different.
CNKS
08-05-2007 19:15:01
 Re: 460 vs. 560 in reply to Owen Aaland, 08-05-2007 18:05:15
I don't have all that memorized like you do, although I do have the engine service manual, I was too lazy to look it up. Should have said bore and/or stroke.
supermpuller
08-05-2007 14:24:05
The heavyduty axles in the 460 are the same as a 560, 460 weight is less
