3cylendered H
Lanse
08-05-2007 09:31:08
My friends dad has a 52 h and three cylenders work fine, but the 4th misses like crazy. He doesnt seem to mind, is that good for the engine? Is that even a decent practice, running 4cylender engines on 3 working ones?
the Unforgiven
08-05-2007 17:49:11
 Re: 3cylendered H in reply to Lanse, 08-05-2007 09:31:08
Yeah, if it has a dead miss it is very hard on the engine. The unburnt fuel in that cylinder is washing and wearing the rings and sleeve like crazy, as well as diluting the oil and causing every other moving part to wear prematurly.
Andy Motteberg
08-05-2007 16:07:11
Change & gap the plug, if that does not do it, try a different plug wire and clean the inside of the distributor/mag cap. If this does not work, there might be a valve problem. I don't know if it is bad to run it on 3 cylinders, but I definently would not.
gene bender
08-05-2007 10:33:11
Find out which one is missing and install a new plug just mite solve the problem
Dave_Id
08-05-2007 10:02:40
If it's a bad valve, sooner or later the valve seat will be destroyed.
Bob Kerr
08-05-2007 09:51:34
Once in a while a plug wire will get yanked of my H by a tree limb and it lets me know it doesn't like it. If under load it sputters to beat the band. I can't imagine it is good on trans teeth or on the crankshaft for that matter to run them like that all the time.
