Farmall 350 Diesel Fuel Filter
Roger46
08-05-2007 18:56:54
I am restoring a Farmall 350 diesel. On the 350D according to the manual there are three fuel filters. There are two on the right side of the engine and a final filter on the left just behind the injector pump. Mine only has the two on the right side of the engine and no final filter. Case IH does not have this final filter. What do people use for a final filter? Roger
Roger46
08-07-2007 18:10:13
 Re: Farmall 350 Diesel Fuel Filter in reply to Roger46, 08-05-2007 18:56:54
Thanks for all the responses. I will check them out. I did get the other filters from Case/IH.
Roger
Evan350
08-06-2007 11:19:27
When I last needed to replace mine about 18 months ago, my CaseIH dealer had a Fleetguard brand filter that is the exact replacement to the IH original. Even has the same little hex bolt on the top to burp it.
georgeky
08-06-2007 11:09:22
Roger, I just got off the phone with Brad and he has those filters in stock. He said they are a little smaller around than the originals, but that is all that is available for them. He also told me they were 57 dollars. Give him a call. 1-888-824-0544. This were to find 350 diesel parts.
farmerweber in PA
08-05-2007 21:48:50
It took some digging,but I can give you a part# on the filter I used when I got mine a few years ago.The part# is A57288.The parts man at the dealership suggested it and it works fine.Had to fabricate a holder for it.It's in the same spot as the original.It was around 30 bucks then(2000).Had to do some plumbing,but used rubber fuel line and haven't had any trouble.Hard to explain without pictures, but George's is probably about the same.Good luck.
georgeky
08-05-2007 20:12:29
Roger, send me an email and I will send pics of the filter. Then you will know what to look for. I will do some checking tomorrow and see what I can come up with.
georgeky
08-05-2007 19:58:02
Roger, I will go look at mine and send you a picture of itif you want. I got it new from IH about 10 years ago. I also got the water trap element. It was 50 dollars. Come to find out I didn't even need it as they are brass and can be cleaned.
