B250-B275 Tractors
Richard Lee
08-06-2007 09:56:34
What if any is the difference between these tractors, can I assume the manual for a 275 will pertain to the 250. Thanks
Fromjb2
08-06-2007 18:18:18
 Re: B250-B275 Tractors in reply to Richard Lee, 08-06-2007 09:56:34
Richard, B275 and B414 are more alike than B250.
I have B414 Operators Manual from 1962. Can scan a page or two for you.
JimB
Hugh MacKay
08-06-2007 17:21:02
Richard: Rick is quite accurate. I wouldn't think the opposite manual would be very useful. The two stage clutch on the 275 will be quite different from 250, then you have the high-low transmission on 275, which 250 does not have. I expect the 4 gears on 275 are similar to the first 4 of 5 on the 250. Then steering is somewhat different.
About the only thing an opposite manual would be good for is engine, electrical and hydraulics.
Rick from NC
08-06-2007 15:12:05
Richard I'm posting this from memory so it may not be 100% accurate. The B250 was made first starting aroung 1955 or 56. The B275 was introduced in 1959. Production may have overlapped for while. Both tractors had the BD144 deisel engine. The B250 had a 5-speed single range transmission while the B275 had four speed dual range (8 speed)transmission and live PTO through a dual clutch. The steering on the B250 is dual drag link while the B275 is single drag link. I think the brakes and hydraulics are similar on both tractors.
I've had a B275 for close to 20 years. It's a good little tractor for running a mower, brush cutter, tiller, etc... Its weak points are Christmas tree light style glow plugs and wear prone steering box
Rick
