130 skipping
Tommy in NC
08-06-2007 12:14:26
130 skips I have replaced all ignition except coil and nothing has changed maybe it's the valves help pls
Al L. in Wisc.
08-06-2007 16:28:16
 Re: 130 skipping in reply to Tommy in NC, 08-06-2007 12:14:26
Is it missing or skipping? If it is skipping, it may not know which gender it is opposite. I'd say georgeky and City-Boy McCoy have it pegged for you otherwise.
georgeky
08-06-2007 12:37:57
If everthing is working as it should, meaning the carb is clean and properly adjusted, engine is in correct time it very well could be a valve. Pull the valve cover and see if one may be stuck open. You can also run a compression check by pulling the plugs and placing a finger over the hole of each cylinder one at a time, as you crank the engine over to see if it blows your finger out of the hole. May only need the valves adjusted. If you don't have one you need to get an I&T service manual as they will walk you through theese things and give vital specs on your tractor.
Tommy in NC
08-07-2007 14:50:45
 Re: 130 skipping in reply to georgeky, 08-06-2007 12:37:57
Thanks for the info.It doesn"t smoke any and I bought a new cab but haven"t adjusted any.I will try the valves next.It has loss of power and skipping bad as soon as you crank it.
City-Boy McCoy
08-06-2007 13:54:38
In adition to the excellent advice George provided, you did not mention smoke. Does it emit black smoke? If so, it is running rich, which will make it run rough and skip. If that is the case, either needs carb adjustment or reset the float level. mike
