MTA w/o TA
Likes Red
08-06-2007 13:08:34
I've been told that Super MTA's were available from the factory without the TA but were still called Super MTA's. Is this true? Has anyone ever seen one?
CNKS
08-06-2007 17:54:39
 Re: MTA w/o TA in reply to Likes Red, 08-06-2007 13:08:34
The SMTA's without the TA had a round decal without the wing. The TA housing was there so the wheelbase is longer than the Super M. Also, the SMTA was the first Farmall to have an IPTO. It was possible to buy a SMTA without the TA but with an IPTO. So, the SMTA without the TA was more than just a Super M with a different decal.
NDS
08-06-2007 14:45:21
Many probaly most of IH tractors including MTAs sold in Mississippi Dela did not have TAs up into seventys. TAs were considered too fragile for hired hand drivers.
John M
08-06-2007 14:30:36
Guy Fay had it explained on his website, but it appears its not working.
Kevin Meier Iowa
08-06-2007 14:18:43
Maybe one of you can answer this then? If it came without the t/a? can a t/a be put in place of the eliminator shaft system they used? Or do you need to change out the entire tub section with one that accepts a t/a?
karl f
08-06-2007 14:10:36
my dad farmed with an MTA without the TA in the 60s til 71/2 when it was traded for a 656. he thinks the tractor had one originally but before he bought it, someone "welded the shaft." which was supposedly a common practice in those days. yours could either be field modified or original as the others have said.
karl f
City-Boy McCoy
08-06-2007 13:58:46
As most of the others have said, it is absolutely the truth. Nat2 explains it best. I have seen one or two. The hood emblem will not have the wing on it, only a white circle, but it still reads "MTA". mike
Andy Motteberg
08-06-2007 13:20:30
I've never heard of a SMTA without a TA, but I have heard of parts you can put inside instead of the TA so it does not have a TA. Is that what a SMTA is without a TA?
Andy Motteberg
08-06-2007 13:18:06
How can it be called a Super M-TA if there is no torque amplifier? TA stands for torque amplifier.
Nat 2
08-06-2007 13:20:46
 Re: MTA w/o TA in reply to Andy Motteberg, 08-06-2007 13:18:06
SuperMTA was the model number for the tractor, whether it had a TA or not. Why IH chose this way instead of having two separate models, I cannot say.
The presence of a TA was indicated by a "wing" on the Super MTA circle logo that said "Torque Amplifier." If it had the wing, it had a TA. No wing, no TA.
georgeky
08-06-2007 13:20:40
Andy, some SMTA's were sold with a TA delete. The decal is a little different on those models.
georgeky
08-06-2007 13:10:04
Yes it is true.
