B-275 Hyd?
Dean E
08-06-2007 17:31:23
Could someone tell me if the three point hyd-rear end-transmission compartments are together or all seperate etc.and what are the fluid levels suppose to be,and what weight fluids are to be used.Thank you very much Dean E Minn
Fromjb2
08-06-2007 18:10:46
 Re: B-275 Hyd? in reply to Dean E, 08-06-2007 17:31:23
Hi B275 has separate hydraulics and transmission reservoirs. Transmission holds 5 US gal of 80 or 90 wt differential gear oil. Filler plug is by gear shift. Full level plug is on side of transmission case by left brake pedal at the floorboard.
Hydraulic housing holds 3 1/4 US gal of IH Hytran hydraulic fluid. It is filled thru the filler plug behind the seat on top of the 3pt housing. Fill till oil is level with top of housing.
Hope this helps
JimB
