Super C serial #
DannyTN
08-06-2007 19:01:52
Where would I locate the serial # on a Super c?
El Toro
08-07-2007 07:28:02
 Re: Super C serial # in reply to DannyTN, 08-06-2007 19:01:52
Look under No1 sparkplug near the radiator for a flat spot with numbers stenciled into the metal.
It should have 6 digits as the first Super C started with 100001. Hal
georgeky
08-07-2007 07:38:16
 Re: Super C serial # in reply to El Toro, 08-07-2007 07:28:02
Hal, did Super C numbers match? I went and looked at one of mine and it did not. I haven't tried looking at the other as it is in tact and has paint over the engine number and can't see it. My numbers on my C do match, just not sure if the SC does or not.
El Toro
08-07-2007 07:45:54
 Re: Super C serial # in reply to georgeky, 08-07-2007 07:38:16
Most of the Farmall letter tractors have this stamped onto the engine block unless the engine has been changed or covered with numerous coats of paint. I don't know why someone would remove the serial number plate from the seat bracket.
Hal
georgeky
08-07-2007 11:02:13
 Re: Super C serial # in reply to El Toro, 08-07-2007 07:45:54
I know they all have a number stamped there, but didn't know if SC had matching numbers. The M's don't, but H's do. Looks like all of them would have matched to start with.
soundmancc
08-07-2007 06:49:54
I have just joined and must have missed the "free cap" post. I just aquirred a Super C and an A with a belly mower. These are added to my M, John Deere H, 35 gas Cat, and 52 International L160. Could you let me know about this offer or where it is in the post. Thanks
Randy in NE
08-07-2007 04:50:10
As the others have said, it "should" be pop riveted to the right hand side of the seat support. If it is missing there is an engine serial number stamped on a flat spot next to #1 (front) spark plug. It may not match exactly but it will be in the ball park.
Pat-CT
08-06-2007 19:59:38
A. Bohemian i said that my h lost the sirel plate and they still sent me one i said i was sorry for not having it and they said they would be more then happy to send me one they are UGLY tho huge black about half the size in legnth of a water bottle
DannyTN
08-06-2007 19:24:15
Thanks. I looked for it tonight but did not see it. Also, what is the stock horsepower of the super C and was it 6 or 12 volt?
georgeky
08-06-2007 19:44:46
 Re: Super C serial # in reply to DannyTN, 08-06-2007 19:24:15
Stock HP is around 23. It would have been 6 volt positive ground.
A. Bohemian
08-06-2007 19:14:55
 From the Owner's Manual in reply to DannyTN, 08-06-2007 19:01:52
Quote:''The tractor serial number is stamped on a name plate attached to the tool box and seat support on the right side of the tractor.''
See what you miss by not having an Owner's Manual?
My grandpa removed the one on my Super C, by the way, and we never found it, which kept me from getting one of those ''free'' gas caps.
georgeky
08-06-2007 20:34:16
 Re: From the Owner's Manual in reply to A. Bohemian, 08-06-2007 19:14:55
They will send you a cap, just tell them you lost the tag. The program has been continued indefinatly due to large supply of caps and low volume of request for them.
jonnny2006
08-06-2007 21:02:10
 Re: From the Owner's Manual in reply to georgeky, 08-06-2007 20:34:16
they sent me three gas caps in the mail and i dint give them a serial number. i was just nice in my request and i did it online. i just told them the model numbers. and years made
georgeky
08-06-2007 19:10:10
Should be on a metal tag that is riveted to the tool box. On the right side under the seat. It may be missing or painted over.
Joe Kimbriel
08-06-2007 19:10:06
It should be under the seat on the tool box, right side.
Joe
City-Boy McCoy
08-06-2007 19:08:47
On a metal tag on the side of the battery box. mike
City-Boy McCoy
08-06-2007 19:14:54
 Re: Super C serial # in reply to City-Boy McCoy, 08-06-2007 19:08:47
That's right - it's a tool box on a SC that is under the seat. (Been around my SH too much!) mike
