C-21 mower
Ralph Thomason
08-06-2007 22:25:16
I have a C-21 mower and I would like to put it on a Farmall H.I was wondering if it would bolt on.Thanks Ralph
Idaho Ron
08-07-2007 19:54:53
 Re: C-21 mower in reply to Ralph Thomason, 08-06-2007 22:25:16
Scotty, care to post more pictures? I would like to see some from different sides, and close up's Ron
georgeky
08-07-2007 20:32:36
 Re: C-21 mower in reply to Idaho Ron, 08-07-2007 19:54:53
Ron, send me an email and I will send some pics of C/SC implements if you like. I have axle mount, front mount, and fast hitch implements for them.
JohnG(TX)
08-07-2007 10:47:12
I have done this on my M. The problem I ran in to was that the PTO shaft would have to be VERY short. The H may be different, but I could not make a shaft short enough for the M. But, it bolted up just fine.
scotty
08-07-2007 04:43:12
Mornin Ralph, I have the A-21 on my 42 Farmall A. The frame that holds the gear box etc bolts between the final drives. The C-21 is essentially the same mower but it bolts up to the axle housing. Im sure it could be modified to adapt to an H but will require some mods ! I have the Blue Ribbon service manual from Binder Books that really helps with the setup.
scotty
georgeky
08-07-2007 07:27:33
 Re: C-21 mower in reply to scotty, 08-07-2007 04:43:12
scotty, it doesnt need anything. It will bolt right up on the H or M. He will need the lift cylinder for the H and a short chain to lift the bar.
scotty
08-07-2007 08:23:04
 Re: C-21 mower in reply to georgeky, 08-07-2007 07:27:33
Mornin George, Yep, I didnt think it would be to much of a change to go to an H but wasnt sure ! Thanks for the update !
scotty
georgeky
08-07-2007 08:29:47
 Re: C-21 mower in reply to scotty, 08-07-2007 08:23:04
Hey Scotty. The only thing is the lifting set up for the bar. Someone here posted pics while back of one on an H with a cylinder he had rigged up on the mower itself. Looked like a nice set up. I may look through the archives and see if I can find it. I am thinking about rigging me one like it. Getting hot here now. Suppose to be close to 100.
scotty
08-07-2007 09:37:48
 Re: C-21 mower in reply to georgeky, 08-07-2007 08:29:47
third party image
Afternoon George, Yep its hot allright, so hot I cant even remember what # mower I have :"(
I have a 16A mower for my 42 A. I do wish I had a mid mount mower for my Super A !
Anyway, just ignore my ramblings, its hot and Im gettin forgetful :")
scotty
georgeky
08-07-2007 10:58:27
 Re: C-21 mower in reply to scotty, 08-07-2007 09:37:48
scotty, they are the same mower for all intents and purposes. I see you have the PTO shield. I bought a whole mower from a guy while back just to get a shield. 50 dollars wasn't too bad for the shield and mower.
georgeky
08-06-2007 22:54:54
Ralph, I sent the email.
Ralph Thomason
08-06-2007 22:48:24
George, would you care to email me ,I have a question about the HM planter drive for a friend of mine .Thanks Ralph
georgeky
08-06-2007 22:37:05
Sure will. I have ran a HM planter on a C lots of times, so I don't see why a C mower wouldn't work on the H. I am going to put one on my H if I ever get My H fixed.
