Super C Throttle
Mike D.
08-07-2007 18:39:52
The strangest thing happened on the super C throttle the other day while driving it, the rpms went down to idle and the throttle lever is all the way up , and it wont go any higher,it just stays at idle speed. Not sure why this is doing it ,but every thing is hooked up, so it must be in the shaft that goes from one side to the other side to the carb. Has any one had this happen to them and if so how do you fix it? Thanks for any help.
teddy52food
08-07-2007 19:41:54
 Re: Super C Throttle in reply to Mike D., 08-07-2007 18:39:52
The governor spring is broken. Take the housing off, the spring is in there. Dealer should have a new one.
