temp and oil guages
Larry B- 1466
08-08-2007 10:03:15
Was wondering if anyone knows what the readings ore on the temp and oil guages on a 1486. Wanting to know what the temp center line should be if that is around 190 deg. Latley mine has been running on the 3rd mark close to the red but is still in the green. The oil pressure is on the center mark at 1600 to 2200 rpms and between the red and first mark at idle. Wish it had numbers instead of marks. Does anyone know the lbs are on the center mark on the oil guage. thanks for any help
