thinking about buying another H
Pat-CT
08-08-2007 15:29:53
im selling my H but was thinking about buying a super H but it has a bad axle seal how hard are they to replace
Pat-CT
08-08-2007 19:19:07
 Re: thinking about buying another H in reply to Pat-CT, 08-08-2007 15:29:53
looked in my manual and says nothing about if i should change the fluids so i guess i will any who ... couple of questions tho theres alot of fluid in there so after i drain it how do i get the sludge out i heard about keroseane but how do i drain and add fluid also where do i bring the fluid when im done
rockerscraper1
08-08-2007 18:05:25
we always put a little white lithium grease on new seal [rubber surface] a little breakin if you want to call it good luck
Pat-CT
08-08-2007 17:46:54
wont that leak
GordoSD
08-08-2007 16:39:41
Save yourself a lot of work. DOn't pull the wheel. Take a razor blade and gut the seal at 12 oclock. Install and put a ribbon of black rtv on the almost invisible crack.
Gordo
Pat-CT
08-08-2007 16:00:03
wow that easy i might have to seriously consider it then third party image
City-Boy McCoy
08-08-2007 15:49:12
Pat: Duck soup from what I am told. I am getting ready to do it on my SH. Go the the caseI/H parts diagrams. They show how simple it really is. Basically, jack tractor, pull the wheel, remove the bearing cap, change the seal, reinstall cap. Be careful not to damage the seal on some rough surface when you reinstall the cap over the axle. mike
