706 LP ELECTRICAL PROBLEMS
L.S.WILKINS
08-09-2007 01:03:26
my tractor keeps burning the points when running under a load,any suggestions to what might be causing this. thanks
L.S.WILKINS
08-09-2007 21:26:18
 Re: 706 LP ELECTRICAL PROBLEMS in reply to L.S.WILKINS, 08-09-2007 01:03:26
thanks john,i'll check to make sure of the ground,we put a new condensor on and a resistor.
John T
08-09-2007 05:15:16
One cause of premature points burning up is a weak or poor grounded (is it screwed down tight) or incorrect sized condensor or else the points gap may be incorrect. Id check the gap and try a new condensor n see what happens. The sparks also weaker if the condensor is weak.
Another cause is excess current like when you use a 6 volt coil on a 12 volt tractor and dont have the correct sized voltage dropping (12 to 6) current reducing external ballast resistor.
John T
Owen Aaland
08-10-2007 00:40:55
 Re: 706 LP ELECTRICAL PROBLEMS in reply to John T, 08-09-2007 05:15:16
The ignition resistor on the 706 is in the wiring harness between the switch and the solenoid. If the wiring harness has been replaced or repaired it is quite possible that this wire has been replaced with a regular copper wire. If that is the case you will need to add a resistor to the circut. Check the voltage at the battery side of the coil with the engine running. It should be about 6 to 7 volts. If you do not have a resistor in the circut you will see 12.5 to 14.5 volts.
L.S WILKINS
08-17-2007 04:11:07
 Re: 706 LP ELECTRICAL PROBLEMS in reply to Owen Aaland, 08-10-2007 00:40:55
sorry not to have replied sooner,busy at work.I will try and look at the wires this saturday and get back with you. Thanks
